Pcktrckt
Perhaps, but their v2 support is done I believe.
@Pcktrckt I'd recommend updating the firmware on the accesport, then unistal it, check maps on it install stage 0, and see how that goes if it doesn't then it's time to reach out to Cobb to see if they can help. Even stage 0+sf would work for you probably better because of the intake
I will give this a shot and report back.
As far as etuning, I've read several thread of tuner doesn't reply back or unreachable. Is this still the case?
Who do you suggest and how would I get in touch with them.So I gotta side with Easter Bunny and everyone else on this, definitely go through an etuner. From what I understand about it
A. Dyno shops aren't really in it for the limitations of your build, they just run it rich and push as far as they can
B. Etuners won't charge you per flash but Dyno show charge by the hour
C. You're more likely to find an etuner that will talk with you and maybe help you understand a little better as to what exactly they're doing to your tune.
Is not as expensive as you would think, that's what I would suggest, personally. Cuz from what I can tell, you n I are about in the same boat. Just search my name, I've been having a hell of a time with my '12 ms3 trying to learn how to tune myself.
