So I'm having a field day with this issue & I'm not really quite sure how to figure this one out. I have looked at the rubber lines leading to the fuel pump & no leaks whatsoever. The odor is very noticeable & worse when you get your face close to the HPFP, could burn your damn eyes with how strong it is. The car is on E85 so the smell of stale peanuts is there. No drips or fuel pooling anywhere over the transmission. I have also checked the HPFP pressure & the readings are coming in normal during startup, idle & under boost. Can't really pin the issue.
Still have to make sure the hardlines aren't fucked to get one thing off my list. Thoughts?
Sent from my Nexus 6 using Tapatalk
