Fuel pressure at idle
Sleepin6
Silver Member
What should the fuel pressure fluctuate around when idle is set at 850 and car is warm? I can’t remember what mine was but now it fluctuates from 400-700 psi. I just want to know so if i have to start checking things i have an idea of where to start. Thanks.
What is normal fuel pressure between gears and on deceleration? I’ve been seeing 292psi when reving up the engine and rapidly letting of the throttle from an idle. Mid 200 between shifts and sometimes deceleration.
That's pretty normal since the injectors are deactivated on decel when in gear. I'll see lows in that range especially when clutching in after engine braking.
Just replaced my prv and noticed black on the top and inside. I wonder if thats normal or if the previous owners ran ethanol.
