Car: 2008 Speed3; 3.5" intake, CS turbo back, AT internals, Reyes Wiretuck, AP v3, (Same tune for years), Damond PCV plate with dual CCs. 180 compression all cylinders, last checked 07/10/2020.
Issue: KOEO fuel pressure won't go above 36psi. HPFP pressure won't go above 1060psi after the car is running. AP reads 0 HPFP Sensor Voltage. Sometimes will pop code P0091. *Attached, see a log of idle with some revs.
Parts replaced: MAF, MAP (CS 3.5bar} Crank Position Sensor, Cam Position Sensor, Fuel Pressure sensor in the rail, FPRV, In-tank pump (1st tried stock from junkyard, currently has new DW 65c), fuel filter sock, low pressure fuel lines (Off tank and to the HPFP), injector solenoid and fuel pump solenoid, injector resistor (used unit), harness coil, and of course spark plugs.
Things I've tried; HPFP ORing kit and cleaning, multiple HPFP housings and internals; jumping the injector resistor, cleaning and swapping spill valves; continuity tests from spill valve to ECU; replaced the ECU, 'hot wiring spill valve buy running the red wire directly to battery, added grounds to HPFP housing.
Short of going to the dealer and having them scope it, I'm out of ideas. Willing to try just about anything at this point.
