I have a 2008 speed3 with around 94k miles. At around 65k miles, corksport short ram intake/TIP, and HPFP internals were installed. Have just run the Cobb OTS Stage 1+ tune since then for these last 3 years on these mods. Recently started getting misfires on startup, then slowly the car started to stutter on acceleration. Occasionally get the P0300 random misfire code. Hooked up Accessport and saw fuel pressure was low, and here is the issue and scenario that has occurred over the last few weeks:
When I would start the car, pressure would show only the low in tank pressure of around 60 psi but sometimes bump up to 2-300psi and back down. The odd thing now is that while trying to solve this issue, I am driving the car with the fuel pressure showing around the low in tank pump pressure of around 60 and the car accelerates fairly well with normal AFRs, unless I get on the gas harder it will stutter and AFRs will flash up to 15-16s momentarily. It seems like after the car is warmed up it will occasionally go up to the normal fuel pressure and at those times I am still able to hit around 1800 psi but havent been into much boost as i'm driving it very cautiously. Short and Long term fuel trims have also been okay, from -10 to 0. I replaced the fuel pressure relief valve and that was not the issue.
Has anyone had an issue like this? What should I look into next? I have searched and watched videos and cannot seem to find someone with a problem like this that wasn't just the relieve valve. I cannot find much info on the spill valve and if it's function/misfunction could cause this. I have not seen any videos or info on cleaning it or issues with it.
What would cause the pressure to stay at that low in tank pressure of around 60 psi and how is that even enough for the car to drive/accelerate? I have not run any ethanol specific fuel/tune. Any help on what to try next would be greatly appreciated. Thanks, Mike
