View attachment 19737 View attachment 19738 View attachment 19739 View attachment 19740 View attachment 19741 View attachment 19742 View attachment 19743 View attachment 19744 View attachment 19745 View attachment 19746 View attachment 19747 View attachment 19748 View attachment 19749 Sooo there has been a bunch of stuff going on, trying to get this subframe prepped for control arms and the like, seems like a never ending cascade of rust and time wasted but I’m steadily made progress and I’m now on a time crunch to get this girl moving again because we’re moving out of this rental house back into our main house (had a fire back on March 15th of 2020, total loss) Anyway that’s happening in two weeks so she needs to be mobile.
One of the decisions to make was to replace the subframe bushings and instead of stock went with the solid set from
@Maisonvi (quick plug: quick shipping and the bushings look quality, thanks again!!) that being said get the stock ones out was a PITA!! Needed a lot of perseverance a hammer and crowbar to lightly tap under the lip and work your way around the perimeter prying it up. The ones toward the back of the car come apart in two pieces however the fronts are interconnected and once they are pried up they get sawed off then pounded out the opposite side, ended up using a 32mm socket and 3lb mini-sledge to smoosh it out.
Now to spot weld (JB) some shady areas then, clean and paint and reinstall!
Oh and also to save $700 decided to delete my power steering and go with a manual rack. Found a local shop here in New Hampshire, Eaton Motorsports. They pulled apart the rack pulled the valves, welded in plugs rebuilt with a quality grease. So should be interesting!!
