Check the resistance on the injectors also make sure that the connection pins are aligned to go into the connector and check that the connector isn't shredded. Inside from bent pins
So I kinda did a hail marry and put in the old injectors. Bam in business. It was the (new) injectors all along. She’s running pretty well now. Thank you all for the input
