Gabriel Buscema
Hey guys! I need some help. My car stutters/chops/misfire under load.
Here is some information about my car:
2007 mazdaspeed3
Engine was rebuilt 3 months ago (bent rod lmao)
FBO, BNRs4, middle of getting tuned with Justin using versatuner
Here's a further explanation of my issue:
When slowly increasing rpm of the car (like 10 percent throttle) the car acts and drives fine and idles like normal
When you give it any more than 10 percent or any load, it suddenly starts "chopping" and misfiring
Will throw an occasional p0300 code but it's rare and when I'm REALLY fucking with it
Now here's what I've tried already
Replaced plugs
Rotated a new coil through all 4 cylinders
Swap in 4 used coils
Compression test (170 on all 4)
Checked grounds
Added an extra ground wire from the hpfp to the chassis
Verified spark in all 4 using a coil pack tester
Verified fuel pressure is good
Verified prv is working
Cleaned MAF
Swapped back in stock map sensor
Verified it is in time
Replaced crank sensor and cam sensor
Took an oscilloscope to the injector plugs (as per Justin's recommendation) and verified a pulse to all 4 injectors from the ECU
There might be more that I cant remember right now
This is my daily so the sooner I can get it running the better
Thanks!
2007 mazdaspeed3
Replaced plugs
Checked grounds
Cleaned MAF
Thanks!
Template public:_media_site_embed_googledrive not found. Try rebuilding or reinstalling the s9e/MediaSites add-on.
