Mike117
I have an 08 speed3 with corksport hpfp internals, short ram intake/tip, and just a cobb OTS stage 1+ tune. I just fixed a low fuel pressure issue by cleaning the spill valve on the HPFP. A few weeks later I now have codes P2178 (fuel system too rich at off idle), and P2188 (Fuel system too rich at idle).
I have cleaned the MAF sensor and am getting voltage from 1 to 3.4... and airflow 1.99-124.98 g/s (probably both would be higher but didn't hit full throttle position/boost) The only thing that is off is that my LTFTs are in the -20.88 to -0.16 range. Range of STFT is -11 to 8.42. From research I am seeing next possibilities being O2 sensors or purge valve? My AFRs are normal and fuel pressures are great, hitting near 1800+ at times. On the V3 accessport I don't see any parameters/voltage from the O2 sensors besides the AFR which is from the upstream sensor correct? So if I have normal AFR readings, the problem shouldn't be the upstream O2 sensor correct? The car is running great but I need to try to find and correct the issue for the car to pass inspection as soon as I can (check engine light). Is -20% extreme considering the car runs well and I haven't noticed any change in gas mileage?...meaning does that sound like a false reading? Is there any other tests I can do or parameters to look at that can help point to the issue?
Since I had a low pressure issue for a long time, (car running with what appeared to be in tank pressure of 60psi) could the car have learned to run with the injectors open too long? Would I just disconnect the battery to make the car re learn or how would I make it re learn? thanks for any help
