I love my Swift springs, but they're only 252 lbs/in (front and rear). The stiffer rear rate helps address understeering tendencies, in conjunction with my JBR RSB.
I have Koni Yellows in the front, and Bilstein B8s in the rear. My understanding is both sets of dampers can easily handle up to 400 lbs/in. So, which route should I go? My main goals are good DD comfort (which I understand will be compromised some), and also a similar articulation rate front and rear. For instance, if I go over a bump on the highway, my rear settles faster than the front because although it only carries 38% of the weight, it has the same spring rate as the front. Ideally, I'd want both the front and rear to settle at the same time for the car to feel more balanced. @phate, @Nliiitend1, and @ConeKiller, and @VTMongoose, does this mean that I should have the same 62/38 ratio in my spring rate to accomplish my goal? Any tips or things I'm overlooking? I've researched all of this, but it's a black art to me and since you guys are pros in this area, I has hoping for a little guidance. Here are the two options I'm considering (as opposed to buying $1,500-$2,500 coilovers):
1) Contact Swift to custom wind springs for me at spring rates I determine. Benefit: could be a little less cost. Also, Swift springs are absolutely top-notch in multiple regards. Sacrifice: I'll still have no ride-height adjustability, particularly for corner-weighting.
2) Contact Ground Control to get their adjustable spring/perch kit and specify my desired spring rates. I honestly believe Swift >>> Eibach, but Eibach is no slouch either. I'd hope I could get linear rate springs, but I'm not sure. This would run ~$450 and I'd retain the use of my Koni Yellows in the front and Bilstein B8s in the rear. Benefit: ride height adjustability (not a big deal - I like about 1" drop anyways), but most importantly, the ability to corner weight the car.
Any insight/experience from whomever would be greatly appreciated.
