Just FYI, for those considering going the Koni Yellows route and potentially rebuilding/revalving them:
"I called Koni and they have 3 authorized rebuild centers for guys that want to change the specifications of their kit on a rebuild. So, the answer is yes, you can change the valving. They said you need to basically have an idea of what the intended use is and the spring rate.
Performance Shock - 800.965.5664
Pro Parts - 818.888.8904
True Choice - 888.566.4722
Let me know if you have any other questions.
-JP (Edge Autosport)"
So the short of it is that rebuilding/revalving is an option with both Bilsteins (already known) AND Koni Yellows. Unfortunately, I don't know the price of revalving the Konis, nor the lead time, but one could easily call the three listings to find out this info.
I know Bilsteins are the cat's meow (@neganox, right?
), but Koni Yellows aren't a slouch either. And since revalving Bilsteins cost ~new Koni Yellows AND offers no further adjustment after receiving them back, I'm going to try the Yellows first. Besides the fact that stock OTS Koni Yellows are able to handle up to 600 lbs/in (according to Ground Control - previously posted above). Even if GC's numbers are overly optimistic and not in the Koni's "sweet spot," my 375 front/425 rear spring rates will be much less than this (~33% lower, which is significant), so I'm anticipating a very good balance between DD comfort/tolerability with a strong performance increase in going from 252 lbs/in F/R to 375/425.
More info to come...
