Wondering if you guys have any thoughts about this situation. Log is attached.
Recently installed a Damond PCV plate, new PCV, stage one catch can, and oil fill breather cap. Other mods are minimal, Cobb intake, balance shaft delete, mild tune from versatune, stock K04, larger turbo inlet, EGR delete w/EGR pipe removal.
This morning I disconnected the battery, took off the (OEM) MAF and cleaned it thoroughly, cleaned the electrical connections there and they all looked fine. Left the battery disconnected for about 90 minutes, came back and hooked everything up, let it idle until it was completely warm and then pulled these logs out of it.
I'm wondering if I have a bad O2 sensor or something? Why is my STFT pegged at 25, and my LTFT never comes off of zero? You'll see my STFT change just a hair when I blip the throttle, otherwise it is always stuck at 25 and even when I blip the throttle my LTFT doesn't change at all.
Air fuel ratios look good, but I had a P2188 pop up so I am trying to chase that down.
Thanks for any advice!
