yes, i have a trickle charger on it.Does the battery have a full charge after all this dicking around
Is it completely losing fuel pressure including low side pressure? Or only high side?
Did you try the tests I suggested?
I've also ran across the broken plug situation and it was when the Speed was still my DD.I always have a spare set in the tool box now.
Yes, you get ITFP pressure when the spill valve is unplugged, just like I said in the prior post.i thought there was a check valve within the spill valve, meaning at an absolute minimum you get ITFP pressure.
