intrigueturbo
My 2012 has about 91k on it at this point and the clutch is definitely slipping and needs to be replaced. I have an offer to sell the car for $7k or I can invest in a clutch replacement and see how much longer the car will go. I don't beat on the engine very often, mostly just a DD with some blast-off fun sometimes.
It has been running a Stratified tune for like 4 years after a Cobb OTS map before that. Have an SRI, TMIC, HPFP internals and RMM on it but otherwise it's stock. I've used Pennzoil Platinum and Mazda filters every 5k since new, use Ford transmission fluid, flushed coolant not too long ago, and had CP-E walnut blast my intake valves back in 2017.
I have enjoyed the car and the only thing I've had to really take it in for was the park/neutral control switch that went bad. I've also got an intermittent airbag light but I think it's maybe just a loose connection. It also hesitates to start sometimes and nobody has been able to tell me why... I'm thinking EGR but it has never thrown a code so I don't know. Should I keep the car and get the clutch replaced? How long can I expect her to keep running?
