Brackets are on order. The studs for the latches need to be shortened, so I am placing an order today for the ones at the length we need, and I will include them with the brackets, as well as the rest of the hardware to be used.
Just a note-please do not order latches now if you plan to use the kit. We are getting a special deal through them on just the latch itself, as our kit uses a custom post for the latch to connect to.
There will still be the dozen screws underneath and the ones up top to hold it in. But that fenderwell bolt itself is an evil thing. This is our way of making it so it is not a factor.
Can genwon owners get away with just doing the one per side in the black bracket like you have pictured in OP? Mine is popping out on the driver's side at the very back.
Just in case this will help. Brackets and latches were out of stock. Wanted 4 latches and was going give up. So tried discount code and worked for latches only. Great discount code!!
