Awafrican
Moderator
just going to put this out there that those on mobile devices typically don't see signatures. I know mine are off and most of my time viewing MSO is on a mobile device.I have a similar issue to the OP that I’ve been trying to troubleshoot for the past week, scouring the forums and I really have run out of solid directions to go in.
When I do a cold start up, I have solid 1500psi that slowly drops down during warm-up as it should. if I blip the throttle once coolant gets above 100°F, fuel rail pressure drops down to tank pressure 50-60.
Once this happens, restarting the car brings me right back to tank pressure unless I let it sit for a while.
HPRV was replaced shortly after the built engine block two years ago, along with injector cleaning and bench testing courtesy of injector RX. HPFP internals were also replaced at that time because the autotechs had sent debris downstream and clogged everything (plastic screens were torn).
initially, I started by checking the two fuel pump relays and then moved onto disassembling and inspecting the HPFP. Nothing out of the ordinary there.
I then checked continuity from PCM pins from 2F and 2G to the spill valve on top of the HPFP. And NOTHING! this was tested with both ignition on and off. At this point, I was pretty confident that I had a break somewhere between the Bill valve and the PCM. Last night I ran jumpers between those two expecting promising results, only to find tank pressure right out of the gate on startup. I then reverted back, and I’m back to where I started. At this point, I’m hoping some of you OG guys may be able to help point me into another direction as you have before!!
Thanks so much.
Also, my signature should have most of the current modifications on the car. Let me know if it’s unable to be seen or if more information is needed
