I will read about it. This is my first direct injection car.I want you to really think about how timing/cams work and how your HPFP functions.
Can you share you knowledge please?I want you to really think about how timing/cams work and how your HPFP functions.
No it doesn't matter how it's installed. There's plenty of instructions out there for hpfp install and none of them make mention of orientation of the camsCan you share you knowledge please?
Because no one took off the entire fuel pump.No it doesn't matter how it's installed. There's plenty of instructions out there for hpfp install and none of them make mention of orientation of the cams
Took 8 qts out? Car still has its balance shaft assembly installed? Doesn't feel like a tank trying to fly when you drove it does it?
Thank you, I felt worried about let the HPFP ''wrong'' installed.To install HPFP internals you have to remove the entire HPFP, so all of them did take off the entire fuel pump. It's run off of your cam which obviously can't time for the engine AND the HPFP, since it's just a metal rod with lobes on it.
No, when I got the car the oil mark was beyond ''FULL''. was burning oil due to excessive amount.Ummm 6qts is max fill... About 7 if balance shaft is deleted.
Are you saying that the dip stick was dry when you added oil? Also blue smoke is burning oil, typically the turbo (especially if it's the stock one) on these cars.
Now you have me wanting a spare ECU that's married to my car just for troubleshooting purposes. Was it difficult to get done?Yes I have, it was a bad ECU. found one used from Ebay for 50dlls + 70dlls for the marriage and problem solved.
What I did to determine that it was my ECU causing the problem was with the car running tap a cable from the negative of the OCV cable and the ground it to the chassis and hear a drop on the rpms. You MUST use a multimeter or refer to the repair manual to know which one is positive and negative. In my case my positive is fatter cable than the grond one.
