KCi
The HPFP pressure holding fine at WOT till 5000rpm and it started dropping flat to 900psi. At the same spot, the AFR run lean. The idle HPFP pressure holding fine at 450psi-ish. No sign of relief valve failure.
I highly suspecting Autotech failures after 50k miles. The WOT log as attached. Appreciate inputs before I spend cash on new internal.
