I was worried it was your original pan that was hitting the ground and then you went and made it stick out lower
Have you considered using a liquid gasket material at the leaky turbo spot? If you can wait until it sets up, and arent twisting the line too much when getting it on, it might be enough to seal once you add a clamp.
At the speeds you are going on the track, would blocking off the area between the radiator and its frame (or inter-cooler and frame) produce a noticeable benefit?
that fire extinguisher mount looks like a really nice piece.
i would make airflow through the front a near term project, it will benifit all aspects of the car, bats, coolant temp, aerodynamics and high speed handling.
basically seal that shit up tighter than a fish pussy
1) that pin for the fire extinguisher looks like a pain in the Dick to pull for release in time of emergency.
2) how hot is your coolant getting? On other cars I've had, coolant leaks have sprung up from hot spots in the cooling system.
How close does that radiator sit to your turbo?
i found the problem
Please put a turbo blanket and heat shields on that thing. My OCD is killing me.
Do you have to worry about running for extended periods of time?
