EatLiftWeld
I just replaced the in-tank full pump assembly with an OEM Mazda assembly. Everything is wired right, torqued to spec, etc. The problem is that the pump is only pushing 4.5-5.5 PSI with the key on/engine off. Which is the reason I replaced the pump in the first place, same issue. Tested the old pump, it was going out, so went ahead and got the new one. If I jump the circuit relay at terminals C & D as per the FSM (not F/Pump 2), the pump kicks on and runs perfect. KOEO/KOEF. Car runs perfect, fuel pressure is good, everything. Drove it 5 miles with the jumper in just to make sure. I replaced the relay with a brand new one, still having the same issue.
I checked the fuel pump resistor, it IS showing 0.8-0.9ohms versus the 0.32ohms it “should” be showing. But, I also jumped the resistor terminals at the harness just to check, and nothing different happened. I haven’t cut and spliced the resistor wires yet, as someone recommended in another forum/discussion.
Why won't the fuel pump kick on, or push 50+ PSI, without the jumper in??
Help. I need my car fixed asap.
