I swapped my infp and now it won’t prime but when I hook it to the battery it primes I’m confuse and getting frustrated someone please help
Why did you swap the ITFP? Have you checked the pump resistor thing in the engine bay on the drivers side near the transmission/headlamp?
should be. youre applying power at the top of the fuel pump assembly right and its kicking on?
If your security light is flashing it will disable the fuel pump. Try disconnecting the battery for a few minutes then reconnect. Sounds like it lost its key programming somehow
Is the key you're trying to use one that has started the car before? If it isnt programmed it wont start the car, you'll have to call a locksmith or take it to the dealer for them to program it
Ok just try disconnecting the battery for 5-10 minutes, then reconnect it and try again. You drove the car before doing the pump correct? Had it been sitting for a while?
