[SOLVED] Injectors 1 and 2 not firing
coalstack
While on a long trip my 2008 Mazdaspeed 3 suddenly lost power and the engine light turned on. Did a noid light test to find that injectors 1 and 2 were not firing. Tested continuity down the wire harness all the way to the ECM with no issues. I even replaced the ECM with a refurbished one and the problem is still there. The noid light shows one pulse then nothing for both injectors 1 and 2 and when doing the noid light test for 3 and 4 I noticed that the pulse seems to be getting weaker and weaker as I crank the engine. Anyone have any ideas?
Something may be in the harness. Time to tear into it.
Weird that conuinty is fine but noise light is acting hinky.
Have you had the injectors tested?
Based on the way he worded it it sounds like the giant connector going into the ECU right at the battery box. There are two connectors
Looks like the entire harness going to ecu here to me on this aus MPS. The PCM is in the passenger for well.View attachment 21994
That's different to my 6 aswell. I don't have a battery box, just a battery tray. Under the tray is a heap of wires coming from ecu in footwell going into fusebox. If I know what the connects looked like that he rebuilt I'll be able to find them in mine
Wtf where is the ECU post your other pic
Is the previous owner relocated the ECU that wiring is probably your problem
He did it's just attached not embedded, (fixed) definitely not pulling our leg. I learnt something today, pretty cool that it's in there.
I'd have to check shop manual to get exact pins for injectors unfortunately I won't have time to jump on the PC this weekend
I was drunk and trying to look at the pictures on my phone. I didn't see the second one
It wouldn't hurt to check all of the pidns on both of those connectors
Some people have managed to fix weird issues by simply unplugging the connectors and plugging them back in
Yeah Im being legit haha. Im not sure out of the 4 are the correct ones. I've unplugged everything and did a Noid light test and nothing changed. So I'm at a loss. I've narrowed the area down to that part of the loom or the ecu itself
When I had issues with mine Noid test was fine, however it was pin in the injector that was angled away from the female pin and not making contact with the harness connector. Bent it vertical and it was fine. This was after an injector cleaning
