Twoodsy
2013 Speed3
Cpe turboback, tuned by Freektune, cobb intake and cobb TIP
No codes
Very randomly occurs and don't do anything in specific to duplicate concern
About 3 months ago I had a similar issue where the cabin interior would shut off and the car died. Found the battery was charging at 14.3v but would die when steering. Found the alternator to essentially overheating and cutting off as a safety measure. Replaced the alternator and battery was it worked for 3 months. This morning I lost power steering for about 2 minutes then it came back on, no interior lights shut off, radio and ac stayed on. I am hoping it is not the electric pump/module but I do know that the fluid has never been done. I plan on checking and flushing the fluid today and checking ground G05 which I know is a direct chassis ground for the EHPAS module. Is there anything else you guys would recommend checking or just starting with this?
Thanks
No codes
Thanks
