Introduction
HOFF
How are ya'll doing?
I bought a broken 2007 mazdaspeed 3 around this time last year. The engine had low compression and spun a bearing on cylinder 4. I ended up 2.5 swapping it from a ford explorer found at Pull-A-Part. I also swaped the 2.3 timing to the 2.5 timing, fixed the P0012 code with a new cam, replaced the turbo, and replaced the cheap cold air intake with the stock intake. I don't want to do anything crazy with it, I just want it as a daily driver. This is my first car out of college and I think its great! There is a boost issue that im trying to hunt down. But I don't know if its apropriate to talk about that in this post as this is an introdcution post, or start a dedicated one about the boost issue.
Hope ya'll have a good day!
:whalecum: to mso!
you can ask about the boast issue here generally we try keep it in the troubleshooting section. when you do ask please list any mods. tuner and things you've done to troubleshoot, first step is going to be a boost leak test
