Brady Buckman
So I bought some fresh serviced (new oem) injectors from CWTurbochargers and did an EGR delete (for some preventative maintenance) for my 2010 genpu and I'm having a couple issues. My fuel trims are way too low (-10 to -25) and I am getting a P0300 code random misfire code and once in a while I will get a P0172 code for running rich. These issues seem to only occur while idling and not cruising or regular driving. I ran a compression test that wasn't so great (185,155,150,185) but before doing the injectors and EGR, I never had any of these issues at all. I checked the typical culprits for these issues (cleaned maf, checked for loose clamps or hoses, replaced plugs with colder 0.026 gapped ones) and unfortunately the issue still persists.
I am tuned by Justin at freektune on 93 with the basic bolt ons (dp, tmic, intake, hpfp internals etc). My only other guess is that my tune learned the fuel tables on flawed/dirty injectors and now the new ones are injecting more fuel causing it to cut fuel % to compensate and potentially causing a misfire for a richer condition. Besides that, my car still pulls hard and seems to drive good but at idle is where it's seeming to have issues. I'd appreciate any advice on where else to go from here. Thanks in advance!
