31N007
inspect power steering system, diagnose why pump whines
- looked at it - it is either the fitting to the pump on the pressure side, or the suction side of things. I don't care overly right now, so I'm just gonna send it!
weld up shift shaft
- done, and painted. No pictures because am pleb. Shortened the shaft by around 2.5" to put the shifter back in a relatively neutral position. This is with the shift linkage changed to interface with the stock Protege linkage. I know the MX3 linkage bolts up slightly differently.
inspect the jackshaft
- Not done, but hard(er) launches have been performed to no ill effects.
front strut tower bar
- No updates here.
New issue
- hood release cable has failed. I suspect it was compromised as a result of the fender bender it was in previously. Going to have to pull a cable tomorrow afternoon (or Saturday) to get things operational again. I fabricobbled a ziptie fix together for the interim and am running sans grill.
weld up shift shaft
- No updates here.
New issue
