Funktionull
Both the front and the rear drivers side are identical and the rear passenger side is about 1/4 to 3/8 of an inch lower.
I have checked and both spring ends are seated in the nub like they are suppose to be and the tops are correctly seated in the rubber isolators. I torqued the control arm down after lowering it to ride height so I know it's not a "tightened in the air" issue either.
I also verified that both springs were identical lengths.
I didn't get to swap them side to side to see if the problem moved corners but I plan to tomorrow. LCA bushings is really all I could think of if the springs aren't at fault.
