KR while cruising + WOT pulls/digs
You only need to worry about knock at full throttle. At part throttle it's the ECU trying to lean out the mixture to save gas totally normal
I
It jumped to 5.95 this morning when I was in third going to fourth going up a slight hill. Not WOT or even close.
Further, WOT knock of <=1 you're good especially if it's just blimps and not pegged at 1 all the way.
Ok thanks a ton. I think the problem is with my current tune I’m running. It may be for 91 instead of 93.
Who's your tuner? Putting in 93 if it's a tune for 91 is a non issue the problem would be of you had a 93 tune and filled up with 91.
You also could have just gotten a bad batch of gas
Seconded on this. To add to that, my MS6 starts getting KR and hesitations if I run the fuel down too low. I have to use a fuel injector cleaner like Lucas and within 5-10 miles it’s back to normal. I should replace the fuel filter at some point…
