brainbot1
Hello all,@Redline
a few weeks back I did a compression test with the help of @VTMongoose to help diagnose my engine and unfortunately found low compression on 2 cylinders. Results were as follows:
1: 180
2: 155
3:160
4:185
a leak down test has yet to be performed to further diagnose the issue but gut feeling and community wisdom is pointing towards worn piston rings. This has prompted the need to run a more conservative tune to extend the life of the engine before an engine rebuild is feasibility since the car has been on the Cobb OTS stage 2 map. And custom tuning is good practice in general so I opted to go with @Jason@DizzyTuning for my tuning needs. my logs can be found attached. Due to my lean condition during the WOT log, there is reasonable evidence that there is an intake leak allowing un-metered air in. I will be doing a full intake tract inspection for cracks/tears and replacing hose clamps hopefully before the weekend to determine if this is true root cause.
Any help in this matter is appreciated as this is my daily and won't be able to afford engine rebuild until early next year.
1: 180
2: 155
3:160
4:185
