Hey y’all. Not new to the forum or the mzr engines. Just picked up a 2007 MS6. I learned my lesson on my ms3 that I still daily and checked compression before buying. 160psi across the board no fluctuation. The car has a AEM CAI and a bnr stage 1 turbo. Other than that it’s stock. It runs extremely lean and will go into the near 25s (afr) under throttle. I feel really bad because I had to drive it home. I did the fuel relief valve test. And it climbs over 1800 before releasing. So I believe that’s not the issue. It’s making plenty of fuel pressure. (I’m monitoring on my MS3’s access port). I’ll have a data log as soon as I get home this evening. It has a couple codes such as random misfire and overboosting (which it’s not) and MAF volt to high or low. The AEM intake doesn’t have straighteners in it so I don’t know if that could be an issue. More than likely getting that replaced because I don’t like the filter being in the bumper. any help would be much appreciated. I forgot to mention that when I got it, it was on a stock tune and I tried the stage 1 plus sf with no success
i did this yesterday and i almost had a heart attack looking at the afrs when I was driving home.
