Littleloogy's ADD & Has a Build Diary
I have to say if it's costing you that much to trailer this around, it seems like it might be worth investigating one of the VCM IDS copies. The cost has come way down. For example http://www.ebay.com/itm/2017-New-VC...4-VCM-II-2-in-1-Diagnostic-Tool-/322619527899
If you were closer I'd buy one to see if it could aid your quest. As well as fulfill my dreams like being able to set all my options without a damn dealer.
Thank you everyone for you input. Once I put the wires in the correct configuration on the connector the AP was able to connect to the ECU and uninstall. My battery was low this morning so I had to charge it up before it could be executed.
Amazing how big of a headache two small wires can cause. No check engine lights are present. Should be good to go now.
I'll put my tree fiddy back with the lochness monster. I'm happy for you though.
crapatalk it sucks for free
Dude that sucks, but is awesome you figured it out. Glad to see this up and running. I understand that frustration (my ecu went bad at one point and I spent days trying to trouble shoot)
Well, I guess it's finally time for break in. Kind of ran out of excuses at this point.
I'll be using 5w30 Dino oil for the first Oil change. I intend on doing an initial start up and run the engine (if it starts) for about 5-10 mins. I'll hold the gas pedal down just long enough to make sure my fuel pressure starts to rise before releasing it and starting the engine.
After it starts I intend on rushing out of the cab and checking for leaks and listening for bad sounds. I'll be going in and out of the cab to fill the Coolant and power steering and rushing back to the cab to press the pedal and get the RPM's to about 2.5-3k let off a few times go back out check fluids and then go back in... etc.
I will then change the oil and filter. When the oil is done draining I'll add 1/2 quart to wash out any old oils that are settled at the bottom of the pan. And refill with 7 more quarts (because of BSD) of Dino oil and make sure to wait until the engine is completely cooled down then I will take the car for a 20-30 minute drive.
First 10 mins I will be avoiding traffic and stop signs/lights. Maybe a big parking lot or a round about. Accelerate to 1.5k RPM engine break to 1k, accelerate to 2k RPM engine brake to 1k RPM, accelerate to 2.5k and back to 1k. I'll do this up to about 3.5k and will not be accelerating any faster then the engine decelerates.
Next 10-15mins I'll be introducing a bit of boost (2-5lbs) to 3.5k and engine braking back to 1k. Then oil change again. By this time the pistons should be seated.
Also, for both oil changes I will be using a shop rag in my funnel to catch any big pieces of metal that may come out.
Haha, Failed.
Tried to fired it up. Cranked for a few seconds then tried to fire it up, and it stumbled and died. When I went to restart it I heard a nice loud Click, then nothing. Starter is dead. It almost sounded like a breaker tripping. I'll get a video of it up when I can.
Haha, Failed.
I would totally groan this, not because you deserve the groan, but because the car does.
Um, so I was playing with the starter and it started cranking again. So I was not about to keep cranking this thing without oil pressure so I released the gas pedal came right to life. Wish I would have gotten a video.
Who knows maybe there was nothing wrong And the car was just camera shy.
Zink or no Zink...
Oil drained all night and I started filling the crankcase with fresh Dino 5w30, I Stopped and thought about adding my bottle of Zink. I heard recently oil was changed and now there is even less Zink additive in the oil now. Thoughts?
Isnt that about the best feeling ever
It really was. I was so happy when that thing started up and check engine lights stayed off for a while. I also was able to put it in gear while it was on the stands and the clutch actually worked. I was pretty happy about that too.
Makes me miss my MS3.
Soon enough you will have it back and it will be better then ever. And if it's not, I'll build you an engine myself. How hard can it be?
Ah, sounds like you might be victim to the starter wire nonsense. Get out, wiggle wire, try to start. Rinse/repeat until it starts.
That's is exactly what happened. In my future workings on the car I intend to run a new signal and power wire to my starter. I am not going to be left in a parking lot for something dumb.
Zink or no Zink...
No the epa made api certified oil drop their zinc and phosphorus levels. I used royal purple break in oil for my first two oul changes then ran conventional 5w30 quaker state until i hit 1k and now im using royal purple hps oil which is synthetic oil with higher amounts of zinc and phosphorus but it is not api certified so dont let those cali commies catch you using anything like that.
Got my first trouble code. During my first warm up.
So I pulled the Engine cover and stuck my continuity probes in the switch and moved the arm that controls the Runner. The operation was smooth but the meter was sure making all kinds of wires noises. The switch was not registering when the flaps were closed. So I used my hand tool to tap on the sensor. That seem to fix the issues.
