JDM Speed 6
Alright guys, so after researching on this forum. Everyone recommended Tribodyn fluid, so I ordered 3 qts of the 75w-90 and did the change on my transmission, t case, and did the limited slip version for the rear diff. After about 300 miles or so, I can no longer downshift into 2nd gear while moving/revs. I have to wait for the engine to drop to idle with the clutch in before it will let me into 2nd gear.
Has anyone had issues with Tribodyn before? I had ZERO issues before the fluid swap. I'm assuming my symptoms are that my 2nd gear synchro is now bad.. which is quite frustrating.
Any thoughts for other things to check? Am I screwed now or can swapping to a different fluid get my synchros working again?
Thanks in advance for any help
