Cfoldone
Silver Member
Hello. So I am blissfully ignorant. My experience with using VersaTune is nothing compared to all of you.
I have, I think a good running one now. My knock was bad until I searched and read up on the Mass Flow
tables and modified using one from forums. SEEMS good now. I have random lean idle dtc. Clears and comes and go's. I will at some point pull Intake manifold, throttle body replacing with AP Super TIG gaskets. Of course valve blasting.. But for now.... Just want to drive...
Tune is off the shelf VersaTune.
Base 93us/98eu Octane - grimmspeed Interrupt. Mod mass flow table for intake mods. Unknown exhaust manifold (see plc) EGR delete....
Data log 2020-08-09 is rolling second gear pinning throttle lift for shifting 3,4,5,6. It starts at the bottom of a 30% grade hill and by the time 5-6 transition is leveling out.
Gen Perf 2020-08-07 is just normal driving. It can be ignored....Unless something bad!
Ign Timing 2020-08-07 is making sure Knock is controlled correctly.
After feedback....Please>>>> I can go into is this all there is? My budget will be 1200 for what I can do to
improve this. S3 ? TMIC ? I only want to stay with HPFP fueling too.
THANK YOU ALL for the help.
