I use meth for the same reason I just want the safety from it, I am using a D10 for the extra fuel and cooling, but I dont expect it to be enough fuel to carry me up to or past 500 HP, maybe it is maybe it is not, I also have a D14 if needed.
I am happy to say though I made a contact and ended up talking with Dizzy and I am going to have him tune my car and I am excited to share the results soon. Here is a basic mod list of my car.
Mods: Wiseco 9:5:1 Forged Pistons, Pauter Forged Rods,ARP Main Studs, Devils Own Meth Kit D10, Garret 3076R T3/V-Band, Custom Air to water IC kit, CP-E CDFP, Cobb AP, Custom power wires batt in trunk, CP-E 3.5 Maf housing on custom Intake pipe, Custom T3 Manifold w/38MM Tial EWG, Custom V-Band DP, Borla Catback, Fidanza 11LB Flywheel, Spec 3+ Clutch, SU rear and front mount, JBR TMM, PTP BSD-Windage Tray, PTFE Mani Spacer, Kenne Bell Boost a Spark Ign Amp, Stock NGK Plugs at around .026 - .028 (I dont mess with Denso, bad experiences with constant fouling), I think I am running OEM head gasket with SP63 Head bolts H11 or whatever (not their first batch the second from A1 technologies), K and N filter with black hole style vortex for smoothing air and I added honeycomb in the vortex opening before maf, I have inline oil filter before turbo with restrictor with a pressure gauge sensor after that to monitor, AEM Oil Press Gauge, AEM AFR UEGO Gauge, of course a boost gauge, and glowshift EGT gauge, also looking into a nitrous gauge to read my methanol pressure (digital reads 0-1600 PSI) waiting to find out if the sensor will handle meth. PTP 1950 PSI Pressure relief valve or maybes its 2150 I cant remember, DCR VVT
