Lesson learned, stand on the breaks in 6th gear and have someone use a 5 foot breaker bar with a long extention to reach the bolt. We combined multiple extensions and the extensions even started to strip a little. Torque lube may have been helpful but I forgot to order it in time. On a positive note, we got the job done and the car is running wellSo I just got a message from @DISIFTW with the attached picture of the crank pulley tool. Looks like there is an upper limit to how much force it can take.
This was trying to remove the pulley, so I guess at this point I will have to recommend that you dont use this tool to hold the pulley off. I thought I had done this before but maybe the one I removed wasnt as stuck as his was. We are guessing that there was at least 200 ft*lbs, maybe more put into this, so be careful if you rent one of these and are trying to break the bolt loose.
Ive used this tool for torquing the crank bolt multiple times (75 ft*lbs and then 90 degrees). So I think it should be fine for that still.
