[SOLVED] Making A Common Engine Section?
AYOUSTIN
Can we have separate drivetrain sections for the 3/6 (to keep trans/drivetrain stuff separate) but an engine section that covers both in the 3/6 General Section? Essentially remove the Engine part from both Engine/Transmission/Drivetrain sections and just make it Transmission/Drivetrain and then make an Engine section in the General Area that covers 3's and 6's.
The reason I'm asking is that I feel a lot of info on engines doesn't get cross pollinated between the 3 and 6 sections. If we have one common area for just engines since it's the same engine in both cars then people will be able to find info on engine stuff a lot more easily instead of having to search through different sections.
