Mazda 6 GG MPS P0091
xNudel
Hey,
I know it came up Like a thousand Times but Ive got a P0091 on my Mazda 6 GG MPS.
I allready checked ground on the hpfp and she gets activated and Sound normal in my opinion. She does around 30 Bars +-2 Bars but still is lean af Even in Idle.
Got 1.1-1.35 afr with Pops and bangs.
Checked compression, Changed the Fuel pressure sensor (Which was actually broken), Like i Said checked grounds, Changed the whole Engine Cables with connectors, checked Timing, Changed Fuel (shes been sitting for a while) and Changed Air Flow Sensor.
The only thing i didnt Change was the hpfp and injectors.
I got the car and it wasnt Running Fine before because there was a Problem with the valves but i Took the Head Off, Took it to a Engine Shop and put it back together and its Running better now but its got These Pops and bangs in Idle and is lean.
Does somebody have another guess what it can be? Im really down for whatever you say.
Thanks!
