Mazdaspeed 6 Downpipe
CorkSport - Derrick
We have made a change with our downpipe offerings! We no longer have the 2 piece downpipe for the Mazdaspeed 6 where you could get the upper and a lower part which bolted to the cat back section of your exhaust. Now we are using our stainless steel cast bellmouth with 3 inch piping with a direct connection to the CBE.
The V2 gives more clearance down the tunnel for wiggle room and an easier installation ad works with stock and stock style bolt pattern turbos like our CST series turbos
-Derrick
Yes the divorced waste gate pipe the smaller of the two in the old style can cause issues with wastegate control if you are running a larger turbo. My tune by Damond needed to have tuner add more control of over boost at top end by using a Ford focus style of adaptive throttle plate and wastegate operation to keep pressure and fueling correct at maximum possible with my fuel set up. Now I have to think about future improvements to mine if... I need more power. Using the old style full 3" tube + cat it's a great sounding and very nice looking. Especially when I work under vehicle. SS and especially the slightly "straw" like discoloration from exhaust flow heating. Werks.
Wasn't sure what you were after size wise, just knew you were interested in more corksport speed 6 parts.
Okay, thanks. Of course always glad to see more MS6 parts, though of course I know that it is a dwindling market. So in a general sense, I'm glad that CS continues to support the platform. But it doesn't happen to be what I was looking for.
I do have a lot of CS parts. I noticed that my signature wasn't quite up-to-date, so I revised my signature with all my CS parts.
