Bar group buy is over, but can be purchased at https://tbperformanceproducts.com/ right now!
The Product
-CNC machined billet mounting cups
-Hand TIG and MIG welded
-Durable high gloss black powdercoat
-USA Made
-Reduce rear end float
-1"x1/2" Rectangular tube steel provides the ultimate in strength as well as a low profile design
-Easy install. Simply remove two bolts and bolt the brace right up
-No cutting or welding
-Clears all exhausts
PURPLE SHOWN FOR DETAILS. Brace will ship in high gloss black powdercoat
Yes this will clear all aftermarket exhausts.
How It Works
The Rear Arm Bar connects both lower arms together which helps improve handling and predictablitiy in corners. This is achieved by reducing the amount of chassis deflection in this area. This deflection causes minute and sudden changes in the vehicles alignment which creates an unstable and unpredictable pattern for the driver. It also makes suspension tuning and adjustment harder as the chassis is throwing an additional variable at the system.
The Product
-USA Made
How It Works
