JohnnyTightlips
Motorhead
How did all the threads for the rail go bad? Isn't there like 4 spots to secure it?
Welp, I got the car back together and cranked her up. Everything seemed fine till I realized fuel was spraying everywhere. The fuel rail has pushed itself off of the injectors and pulled the remaining threads out with the bolts, not good. We're going to attempt to fix the lack of treads with a Heli-Coil.
Brightside: No misfires in the 20-30 seconds it was running.
No, that plug just goes to a switch that tells your computer that the runner is in the open or closed position. Most just delete the code in ATR and never look back. The only problem that could affect the engine performance is if it were stuck closed, but is unlikely.
They look like the bolts that hold the front seats in place.Just found these bolts in my back seat, not sure what they go to.
This might be the end, my car now starts and idles fine after installing new coils, but misfires like crazy under load. It's throwing the code for cylinder 3. I pulled the coil and plug and checked and it's got a decent amount of standing oil in it. Is there any hope of saving this engine besides a full rebuild?
Most likely rings, as that was the issue for mine. I ended up selling that hunk of junk and got something surprisingly more reliable.Hey, did you ever get this solved? I'm having a similar issue with a cylinder 3 misfire under acceleration. I've already swapped around plugs and coils and replaced the injector yet the problem persists.
Any help is appreciated.
