So to clarify, what is making you think there are misfires, are you getting a code? From what I can tell, your AFRs in boost are looking good in the 11s, I don't see anything too wild off the top of my head, except your Long Term Fuel Trims are a bit high indicating a boost leak somewhere, wouldn't hurt to do a simple boost leak test, capping off the valve cover vent port.
On deceleration (in full vacuum) your AFR is going to read 29.25 because there is almost no combustion happening in the cylinder, ergo mega-lean reading, which is expected and normal.
What are your mods?
