I have a motor that was missing on cylinder 4, same code you have. Burnt exhaust valve was the culprit.
how bad was that to get fixed? What did you have to pay for that?
There cx7 will work. It's pretty much the same as the gen 1 Mazdaspeed 3. You do need to be careful with them as most of them are not well maintained and oil coated valve train. It needs to be there turbo 2.3 not the NA 2.3
Cx 7 motor is lower compression. It will work but performance will suffer
They run regular fuel though.
I always thought the motors had lower compression and a smaller turbo
