Enki
Moderator
Don't use oil to lube it. The HPFP gets quite hot and mixes with fuel pretty readily. Obviously, this can cause issues if the oil can't handle the heat loading while mixed with said fuel. Also, cleaning the spill valve is a supremely important part of cleaning the HPFP so you're going to have to do it again anyways since you *technically* didn't actually clean the whole thing.
If there's one thing I truly understand about this car/platform, it's the HPFP.
