Mrs DB's Money Pit
Mr Dangly Bitz
Since my wife wont make her own build thread here, I will. Hopefully she decides to join and update as she progresses, time will tell
Since she has been very suppportive of my rather expensive project, last November she was able to source her own.
There are rules I must follow and she checks me if i deviate like a savage.
1. it is her car and hers to rebuild/modify/restore as she sees fit
2. I am not allowed to work on it without her present and only if allowed
3. I am used to turn stubborn bolts and hold the flashlight.
With that out of the way, here's her project. An all original 1972 Datsun 240z 4 speed.
Once we got it home, gave it a quick cleanup to see what we were working with. Its a 10 footer, was originally orange but resprayed red a few decades ago, not much rust to be found. Floor pans are solid, but will need some love to get it shining again the way it should
First thing we did was diagnose any leaks we found. One obvious one was at the mechanical fuel pump. It would drip gasoline right on the alternator, so that was a fast track replacement before going further.
After that she changed out the radiator, removed the AC compressor, pulled the air pump and the entire emissions control setup wich was rotten and causing exhaust leaks. Replaced all the coolant hoses including the ones to the heater core as they were brittle and starting to leak and flushed out the mud that was the coolant in the system
Next was to tackle the carbs and the very obvious exhaust and vacuum leaksIMG_2290.jpg
Once everything was pulled from that side of the engine it was clearly apparent that the leaks must have been there for months and been tuned around. The block is actually painted blue but cant be seen due to all the soot and grossness that accumulated over the years
There were a few manifold studs that were snapped in the head which contributed to the exhaust/vaccuum leaks. They came out suprisingly easily. while we had it open we did the old school MS walnut media blast of the valves to clean up the intake and exhaust runners.
Over the next few weeks she took apart, cleaned and rebuilt the carbs, I wire wheeled the intake and exhaust manifolds just to clean up the looks of the engine bay and give the car a fresh look
She put everything back together and it actually looked pretty nice in the engine bay. Definitely jealous of all the room to work on it compared to the speeds and the RX
Finally it was time to tune the car, most of my carb experience is with small engines like lawnmowers. so this was uncharted territory for both of us, especially dual carbs with a balance tube and variable venturi's.
After a cleanup and some tuning (still not done at this point) it runs decently well and comes to C&C. Shes gotten more popular in the last 4 weeks than I have in the years Ive been going. Everone loves it and wants to see it/ has stories about when they had one or wanted one.
Just for fun, she crochet'd a tongue for it because why not.
Immediate plans for it are to send it to get the underside and engine bay dry ice blasted to just clean up 50 years worth of crud. replace the suspension, run through the brakes and get a boomer to help us get the carbs and timing right. Maybe swap the gearbox out for a 5 speed and replace the clutch just to be safe.
I know where I would take it next but, she wont tell me her plans. Until then I stand at the ready with a breaker bar and flashlight. Will update as we go further along.
Nice! Always wanted a 240. Very clean! Man... Aside from all the red, Im very jealous of the cars in your garage.
So some updates with the Mrs project
Picked up a full bushing replacement kit for the car as well as all new ball joints, tie rods springs struts etc
Winter has been cold here so working in the garage has not helped with motivation
Also bought the Mrs a micro BBK from wilwood to replace the front calipers and convert the rears to disc.
to date we have all the old out and 1 corner 50% complete. hopefully the weather warms up soon so she can push through the rest of the install
current status of most of the suspension
Me helping
Nephew wasnt satisfied with the condition of the components and offered to paint
and a pic of the BBK still in the shipping box
Soo finally an update
Over the winter we pulled the valvecover to check clearances between the cam and valve springs, while we were in there did an old school mod and jumped the cam forward 1 tooth on the timing chain. then did a compression check - went to 180 on all cylinders
PHOTO-2024-05-28-19-51-51.jpg PHOTO-2024-05-28-19-51-52 (1).jpg PHOTO-2024-05-28-19-51-52.jpg
Rebuilt the distributer and played with timing, now needs 93 and octane booster because its got real powah now. Still gotta fiddle with it a bit, but idles smooth and cruises no issue. have a breakup around 4k, thinking its the condenser but thats an issue for another day.
all the bushings have been replaced, new struts/shocks springs are in.
Brake system flushed, new brakes are in. Took hours to bleed correctly but finally got it done on saturday
Eyeballed the alignment on the front and took it for a drive, went to a local car show. first time the cars been on the ground since november.
Topped off the diff and transmission oil since they both have minor leaks
Shes taking it for an alignment and inspection this week hopefully,then we can focus on my pit
So right before the end of the season. Mrs DB's waterpump decided to take a shit
Drained the coolant and replaced it last night. Also pulled off the extra brackets from the dealer installed AC system that doesnt work
Got it all back together but havent turned it over yet. She snapped the tensioning bolt on the belt for the alternator, so that will need to be sourced and replaced.
Next steps over the winter are to drop the transmission, replace the gaskets on the input and output shafts, replace the clutch and replace the rear main seal
Exhaust is also very cobbled together with tons of leaks, trying to convince her to buy a full 6-2-1 exhaust system. Will see where it goes.
