MS3 PCM fault?
WFVCcXqWAy9vkYxb8
So would something like this not be trustworthy?
The HPFP cylinder sleeves you pictured are supposed to say Autotech, you can check there.
Removing the HPFP piston will just confirm it.
That’s your stock internal I can tell I replaced mine but when you replace your suppose to also get cams after words then tuned..
Incorrect you do not need to be tuned for hpfp internals nor do you require upgraded cams.
Also welcome to MSO I see this is your first post replying to two year old threads with misinformation where the OP hasn't responded and others have helped with correct information and pictures of not a good way to make friends.
Edit: that was quite brash of me, hopefully you find any information you're after, plenty to be had around the forums. we're here to help those that want to learn learn.
