Hello! I am having occasional second gear pop outs on decel and consistent second gear grinds when the trans is cold. I already tried adjusting the shifter cable responsible for left/right movement (couldnt find info on adjusting front/back movement), so from what i hear most likely fork pads. I am considering either rebuilding my trans or buying another trans to just swap out before i sell my DD mz3 and am down to just the ms3.
I found a guy selling a second gen trans that I'm considering, especially because of the slightly longer gears (for autocross), but does anyone know if the second gen trans will bolt up in a first gen? ie. same bellhousing bolt locations, clutch fits, axles fit, sensors all plug in the same, etc.
thanks!
thanks!
