MS3 Sparks One Time, Won't Start.
  • Thread starter Thread starter Sig32
  • Watchers Watchers 9
An oscilloscope is really expensive. If you have Forscan see if you can go to the data view for your sensors then see if it has a graph function.
Like I said before I doubt this is an issue if you aren't seeing a DTC for a crank/cam sensor. Those are type A DTC'S which set immediately upon an error occuring. If you have no code for that then I would look elsewhere
I'll look into Forscan this evening and see what I come up with. Based on what I have stated, do you have any suggestion as to where I should focus my attention?
Sig32 did you solve the issue? I am having the same problem currently.
There's also a guy on Facebook mazdaspeed group that's having the exact same problem with the exact same issues did you find a solution?
I dont know what it could be ive gone through all my looms over and over again just checking it out, im running out of ideas, on that post on facebook i was told if my valve cover is painted it will be making the cam sensor sit too high and the cam sensor cant get a pulse
