First off, short mod list. Stock engine, BnrS3, 3 inch intake, HPFP internals, magnaflow catback, tuned with Versatune, and now, a catless downpipe......
So today I installed an Ebay catless downpipe on my MS6. After the hell of getting the old one out, (seriously screw that thing), I got everything buttoned up, and it runs like crap.
A few things that I noticed:
1. The vband connection was leaking at first, so I tightened the crap out of the clamp. I think that fixed it, but I'm not positive.
2. The downpipe doesn't line up at the exhaust end because some previous owner had the magnaflow catback MODIFIED to fit their crappy test pipe and oem downpipe. So the flange is at the wrong angle. I wouldn't think this would be an issue as far as idling, but maybe I'm wrong.
3. I took a log, and the STFT's are pegged at -25% when idling, and the AFR is quite rich too. Granted this was a cold start, and I didn't let run too long because it's super loud now. But 11.4-10.3 seems excessive.
I also did make sure that the MAF sensor and 02 sensors were plugged in.
I've attached the idle log I took, although there are some spikes at the beginning and end where I revved it a bit. Does this look like an issue with a vacuum leak or exhaust leak? Or is it something else? I was thinking a downpipe wouldn't necessitate a MAF calibration, at least for idling, but maybe it does. I'm kind of at a loss.
