I am considering replacing the OEM H1 halogen hi beam bulbs with LED to possibly lower the in housing temps. I have never converted anything to LED headlights and have a few questions. I hope someone has some experience or insight. Has anyone been successful installing LED H1s in Speed6 hi beam housings?
H1 LED are said to run cooler than Standard H1 55W halogens. In researching, there are heatsinks or fans on the back of the LED units. Also, a couple sites mention that the back of the LED units get pretty hot How hot blog & Motorbiscuit. It would appear the fan cooled LED units run cooler back side temps.
-Is there enough room inside the housing for these types of units and is the back cover in danger of any of this heat?
Also, most LED H1 lights I see come with a separate "driver". My LED fogs dont have a driver...therefore confused.
-Is that only required for Canbus reasons and not needed on our cars, or do all LED H1s have it?
Back story...
A few years ago I replaced the lenses on my Speed6 headlights. Last fall I noticed some of the outer coating was chipping off the outside of the lens on the passenger side above the high beam bulb. I assumed it was due to the typical cheap online product I purchased. This weekend I noticed over the drivers headlight was doing the same thing, leading me to consider the heat from the standard 55W H1 bulbs (I have never replaced them).
My current bandaid was to apply wrap over the lenses like a set of eyelids to cover the area. I chose black as i wasnt looking to make this an appearance related modification and wanted it to blend in as much as possible...
Back story...
