ms6mil
Continued.....
January 19 2016,
Cleaned up the engine bay a little bit... unfortunately the car started running a little rough.
So.... I pulled that mofo out!
The motor is off getting built by Ebtec in Atlanta, thanks to Chris Murphy for the help on that.. In the mean time I will be completely cleaning out the bay, replacing parts here and there and getting the injectors cleaned and tested.
I am unsure if this is normal with injectors with the seals but they are pretty grimy...
Update: new Seals:
Also... If anyone who is reading this can point me in the right direction for a replacement connector for the alternator. I sort of cracked the clip when I was removing it.
Update: I found a connector that works....
Feb 21, 2016,
Gutted the engine bay and clean and coated:
For the turbo, manifold, and WG I went with the BB PTE5862, CPE mani/Tial WG combo from Edge. ACT 6puck plus a bunch of new SS lines and fittings throughout the car.
Breaking down the PS pump for a rebuild...
I'm told 2 more weeks for the motor.
Gives me enough time to get the last few items I need and this thing should be like a whole new car.. Should be a beast!
January 19 2016,
Update: new Seals:
Feb 21, 2016,
